Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I have a 1990 115 HP V-4 that I need to pull the flywheel from. What's the best technique to hold the flywheel while removing the nut and then pull the flywheel?
If you use an impact wrench to take it off, you still need some sort of a flywheel holder to hold it to properly torque the nut when reinstalling. Don't think you can get by without using a torque wrench. Tons of motors have been ruined that way.
I just removed my flywheel from a 1998
Johnson 115.
Used a flat Bar placing the back of the 45 degree
angle against the timer mark and the end in the
teeth of flywheel. Get a 2-3 foot piece of pipe and use
to extend breaker bar. Some one holds the flat bar
while you use the extended breaker bar.
Does anyone know the thread spec on the three holes in the flywheel for the puller. They don't match anything in my puller kit. I am not sure if they are partially stripped or not.
Grade-8 bolts will work. Don't attempt it with the grade 5 bolts usually provided. Don't pull on the outer diameter of the flywheel when your are removing it. Be sure the flywheel and crankshaft tapers are clean and dry and use a torque wrench to tighten the nut to 100-105 ft lbs when you are done. Just thinking you tightened it enough with a regular wrench would be a fatal mistake.
