swarfmaker
- Aug 28, 2007
- 3
I just bought a 1980 80 hp mercury that was rebuilt a couple of years ago and I was told it ran fine. However it sat for about a year. When I run it it idles fine but dies when going into gear. I've checked compression and get 120 psi in all cylinders. It won't develop power at all. Here's the weird thing: I took it out on the lake last night and discovered that the lower carb is not sucking at all. You can close off the idle needle completely and it has no effect, nor when running with the butterfly valves open do I get any suction into that carb. If the reeds were bad I should get blowback out the carb but I don't. Any suggestions? Anyone who gives this a little think will be appreciated!
