I know someone on in this forum will have an answer to these problems on my 89 Merc 60hp.
1. The high temp alarm allways goes off , but only at full throttle. I have changed the impeller and there is plently of water coming out of the tell tale. I have checked that the sensor and its wire were not loose but it still goes off. Is there any way to test that the sensor is working properly or should I be checking something else.
2. I allways smell raw gas from the engine and can see it drip from under the cowling near the tiller handle. I have checked all the gas lines and even removed the air box to look for puddling while the engine is running but did not find the cause. The only area is see any is on the bottom of both carbs where the throttle shaft passes through them. Any thoughts.
Your help is appreciated.
