Cromagnon35
- Aug 31, 2007
- 4
First post for this new boater, please be kind ;-)
I've purchased a 1983 Penn Yan Game and Fish 18 with a 2.5L OMC stern drive and have been having a hard time getting it to run consistently well.
It was abused a bit over the last winter (at least) having been left out, uncovered, in the heavy snow and I believe it filled up with water and froze.
Immediately apparent that it was waterlogged, I:
changed the oil (mostly water) ran it for a few min and changed again.
Drained the gas tank and refilled with 87 octane.
Replaced a freeze plug that gave out on it's first launch (checked - oil is perfect, no water).
Tuned up with new dist. cap and rotor, plugs, wires, Carb Kit (2bbl Rochester 2gc), fuel filter, points and timing.
Engine starts easilly and runs fairly smooth for a few minutes then loses RPM's and dies and/or loses power. Restarting is sometimes difficult, but seems to work best with throttle set at idle.
To me it seems the issue is related to the warmup -
* Could it be the choke? is there a trusty way to set the Choke? This carb seems to use an air/thermal choke, which I'm unfamiar with.
* Might there still be water getting to the gas? Would it be worth putting a fuel/water seperator filter in?
* Could it be the coil? the one on it came with the boat.
The big boss (wife) is getting tired of me throwing money at it and I need to be a bit more selective on what I apply funds to.
The boat is otherwise in great shape and is the best riding/handling in this size class I've been in, it'd be a waste for me to let 'er go.
Help!
Help!
