8hp mercury missfire
seasalt
engine was very bad to start from cold.traced fault to diagphram @ replaced same. engine now starts like a dream. but, after starting the engine will run but has a missfire/pre ignition when the throttle is opened ! new spark plugs were fitted at the same time. the motor has been in my possession for 4 years now been no problems. could any1 throw any light on the subject !
Windykid
Re: 8hp mercury missfire
What year is it?
Plug fouled?
Water in fuel?
Laddies
Banned
Does the engine have a ign miss or simply backfireing when throttled up
seasalt
engine has missfire when at tickover but this is intermittent & still missfires/backfires when the throttle is opened. it is a 1997 motor . no fuel probs it is new fuel. the motor is off the boat in the vice on the bench in a tub of water for testing purposes only. i have no workshop manual for this motor so any set up information would be greatly appreciated.
Laddies
Banned
Heres the test for your ign from CDI. it's tough to find that kind of problem without a induction tach or dva, if you have a induction timing lite it can find the bad cyl at idle and just above
Laddies
Banned
Sorry this didn't post the first try
