ddrieck
- Jul 12, 2007
- 673
working on a 1978 Mercury 500 50. The cheap Clymer manual I bought indicates what wires to test the trigger and stator when performing an OHMS test but says to go to a Mercury Dealer for the voltage tests. What should the stator and trigger voltage's be? Also in what sequence should the wires be tested? Is it the same as when doing an OHMS test? I do have a high doller Fluke Digital Volt/OHMS meter( AMP Clamp). Will this work in place of the DVA?
