two-stroke engine...new gas, new oil...Just had the carbs rebuilt, lines flushed, new spark plugs, new water pump...took it out three weeks ago, ran like a champ...
took it out on saturday...went to prime the fuel line and the bulb would not get stiff...got up to speed and it started to "cough" and then died...smelled gas...thought it was flooded...waited 10 minutes, started it up and it started ok but then i couldn't get it up to full throttle...checked the bulb, it was firm...whenever i tried to get to full throttle it would die...i could run it at a low speed just fine...thought there might be air in the line, ran around the bay for about 30 minutes and still could not throttle up...put it on the trailer
my thinking is its a fuel starvation issue...the fuel line and bulb are original...i can fix simple things, im hoping to get a better idea of a possible diagnosis before i take it to a mechanic and drop a lot of cash...im wondering i may have a leak somewhere...i didnt have time to look for anything while i was there but will be going back this weekend...
any help is much appreciated
thanks
thanks
