jddenham
- Aug 8, 2006
- 393
I was just at the dealer inquiring about gear lube for three motors I have. 1959 Johnson 50HP V4, 1973 Johnson 115HP V-4, and 1975 Mercury 1500 L6. He said I could use the same lube in all three units. He also said that I could use any 80W-90 gear oil(lube?).
Is this true? Non of the units are electric shift.
Is there a marine spec similar to 2-stroke oil?
Would it be better to use a universal type gear oil from walmart and change it often, or use a manufacturers and change it per regular intervals?
What would be a good oil I can use in all three engines, or is there one?
