Re: Marine Plywood
Thanks for all the helpful info. While at Home Depot, I found 3/4" underlayment, Birch, that was hard to pass up. The exterior ply at the local yards and Lowes and Home Depot were shoddy and I was staying away from pressure treated due to a potential reaction with the aluminum. After all this, I took off the old deck (original panels from 1975) and it appears that the ribs are actually galvanized steel. Where there was the most rot in the wood, there was a good deal of surface rust on the ribs/crossmembers. They're still solid, only one has enough rust to flake, but each shows some rust. I don't know the term, but the welded "stands" from the pontoons to the crossmembers are aluminum as expected with no signs of corrosion or any reaction where they meet the crossmembers. Anyway, I went with these birch sheets and a good poly to seal. Hopefully, I won't be kicking myself later. I'll still use a good caulk, stainless fasteners, and rubber washers/grommets as much as possible.
