Re: Best Anchor for the buck
I just use an anchor rope rated for 2 tons that I picked up from Wal-Mart. If you use chain, depending on where you are anchoring, you can easily get into 200 lbs. of chain in no time. I sometimes anchor in the Ohio at 32ft. When I anchor in I throw it upstream as far as I can, and when it hits bottom I tug really hard to get it to dig in. On a clay bottom, I still say Danforth is the best. I have brought up spades full of clay 3 inches deep before when I brought it out. Of course, all you have to do is slosh it around in the water a few times over the boat, and the clay fall off.
I've tried the old mushroom shape, a spade, and the CQR type. I about took the end of my finger off with the CQR. The Spade never came off the bottom since I had to cut the rope after 30 minutes of pulling, and the mushroom shape I still use if I'm going to be in a rocky area. So, from my using them on my 20 ft. boat I think the Danforth is the most economical and best all around anchor for a boat.
