boat steering,water hot
garydow
my boat 1995 wellcraft sat for 10 months. started up today and the water coming out keeps getting hotter . what should i check. also the steering has locked up and will not turn.
HighTrim
Re: boat steering,water hot
Im sure a water pump rebuild is in order, do it first before that impeller explodes causing catastrophic consequences. Your thermostats could possibly be stuck as well.The thermostat is required to keep the outer wall surrounding the steel cylinder, and the cylinder wall itself at a temperture to compensate for the distortion of the pistons. How long was the motor running before she overheated??
