What size boat with 90HP O/B?
CelticCavalry
Hello, I have a 1990 90 HP O/B Johnson on a 19' hull. The hull is being junked, but the engine is still good. I am currently looking for a newer hull. My question is, up to what size boat can a 90 HP engine go on? I found a 20' Center Console but I'm not sure if the engine is big enough...
Thank You in advance...
Kevin
NY
Jeff23
Re: What size boat with 90HP O/B?
Well, I'm no expert. But it depends somewhat on the hull designs. Some boats (Maritime Skiff is an example) are made to run with moderate HP. I'd venture to say that aluminum boats need less hp than fiberglass. I have a 16' McKee with a 50hp Johnson on it--replaced a 70 hp Evinrude and the 50 planes it just fine even with four people aboard. But the McKee isn't made to run through steep chop--more a bay boat.
Good luck with it--I'm interested in seeing the answers you get.
Jeff
CelticCavalry
Thanks Jeff.. I am looking at fiberglass boats only... The aluminum boats tend to toss you around a bit. The 20' I hull that I found is a 1987 Angler CC.
Kevin
Jeff23
Hopefully one of the more experienced guys will come by and enlighten us re: the Angler hull :)
Texasmark
The 90 hp engines I am aware of have a 2.3:1 (thereabouts) gearbox which runs at a lower rpm than the higher hp enignes. This allows you to turn a larger prop with less pitch, both elements of pushing heavy loads.
The hull design is your biggest concern. Flat boats plane out with big loads easily but pound you to death in any kind of sea. Deep V hulls are great for rough water but there is minimal planing surface so you have to push them thru the water.....rather than them riding on the surface sort of thing.
The semi-V style attempts to give you the best of both worlds: sharp wave entry and flat planing area.
Obviously weight, and weight distribution are key elements. For stern heavy boats trim tabs help to keep a stern up with low hp.
Wave action is also part of the equation. Much easier to plane out on smooth water than rough.
How fast you really want to go is paramount. If you are happy running at WOT just on plane that's one thing. If you want white foam that's another.
Trim or not is also a big player as is "setup" of the engine to the boat interface.
There is no textbook answer to your question. It all depends, including which is the right prop. The only way you really know is to try it.
In short, with a good efficient semi-V hull of moderate weight and loading, you should be able to go to 20 ft and run 25 to 30 mph on calm water with a moderate load which is not bad.
Go to www old-omc.de and look at some of those boats and what's pushing them. You can get an idea as to how fast they are running by looking at the size of the water droplets in the spray....the smaller/finer the spray the higher the speed. Also they are probably empty, other than the passengers you see so if you loaded the boats up for a good sized fishing trip, performance would surely be different.
Also for those pulling skiiers, notice they are usually young women on large double skis.....my wife weighed just over 100# when I married her....I weigh 250 and like(d) to slalom. Makes a difference what pulls each.
HTH
Mark
ezeke
No expert on Angler, but the 1987 20F boat lists maximum HP at 185. Based on the 70% rule of thumb, 90HP is grossly underpowered. That being said, the 90HP will still get you out of the hole if you prop it low enough and don't care about speed.
http://www.iboats.com/Angler_Boats__20F__1987/bp/64b3164r0
BTW, the advantage with aluminum vs fiberglass is weight; aluminum hulls generally weigh about 30% less for the same size and strength.
Benny1963
i am running 17 ft mckee rated at 120 hp i am running a 1981 evin 150 crossflow with smart tabs it runs 55 on gps had 1972 65 hp elec shift
on while i was doing power head on 150 it ran 28 trimmed all the way up with 1 person at 5000
iwombat
Like was alluded to before a lot depends on what you'll be doing with the boat. If you're pulling skiers, or outfitting a bass boat and hole shot as well as top speed are concerns, I think you'll want to stay under 18'. If it's a deep water fishing rig (not hole-to-hole zippin' bass boat) and getting up on plane quickly isn't a concern, 20' isn't out of the picture. But, don't expect a lot of top speed.
"It depends" is going to be the going answer until we get some idea of what you're going to use it for.
CelticCavalry
Thanks for all the help....
I won't be pulling any skiiers...just cruising around....mostly just for fishing in Long Island Sound. I don't go offshore, so that's not a concern. I also don't mind it being slow. As long as it will push the boat without straining the engine too much, I'll be happy.
Thanks again for all the input....
Kevin
tashasdaddy
prop it correctly, no problem. moving to boat topics,
I have the same Johnson 90 on a 17' CC semi V hull at about 1800 lbs. and with 2 persons goes 35 mph max at 5000 rpm. Your 20' would be heavier and therefore slower.
Texasmark
35 mph is not to be laughed at.....that's a nice clip.
I was out the other day just putting along and seeing what 20 to 25 mph feels like and you are moving right along there too.
So for a guy that's out to do some fishing and not to "be the first at the honey hole" you should do real well.
Besides the ride is real relaxing; no bone cracking jolts. Grin
Mark
Jeff23
Well, I was out on Long Island Sound last Sunday and saw a guy in a 20-ft angler with a 90-hp engine. Maybe by now you've bought the hull and it was you! He had three people in it and was running at what looked to be a good clip near Duck Island.
