wildmaninal
- Jul 14, 2007
- 1,897
Hey
Well I got the idea to put an aluminum sheet down for my deck to reinforce it. I did seem to have a little weak spot toward the corner where the live well and storage compartment meet. I currently have my boat down at my uncle's upholstery shop to have the bottom of the boat patched (for a few bare spots I'm worried about), and I am going to have carpet installed (I know some of you are frowning about the carpet
). I feel the boat is going to be gone for a while because his shop is busy. I was originally going to have snaps installed on the carpet so I could remove it but my uncle said the carpet will stretch over time and may cause tripping hazards and it will look horrible. Well he talked me into glueing the carpet down. I plan on having the boat covered when not in use anyway, I know the carpet can get wet while out on the water though. My thinking led me to say if the wood rots out from under the aluminum (hopefully years later) I would just half to take the aluminum up and clean out the rotted wood. Here is my website to get an idea of the boat I am talking about.
(this website works good so far compared to the other I built)
My questions are:
What thickness aluminum sheet should I go with?
If I get a flimsy enough sheet I should be able to install it without separating the hull even if I half to cut the sheet in two right?
Would I need to seal it? If so what with and when during install or after install?
Should I just give up the idea of reinforcing it?
Would a graded material (like they use on some utility trailers) work just as well to save on the price of the aluminum sheet?
Would you go with snaps on the carpet over glueing?
I can use some ideas here
Thanks guys
My questions are:
Thanks guys
