I just purchased my first boat and I am up against my first problem before ever getting to the lake and could use your advice.
Boat Specs:
1977 Ranger with Johnson 115 (I think its V4)
My Problem:
The Tilt and Trim does not work.
What I have done so far:
Following the advice I have seen in this form I disconnected the Trim motor from the sylanoid last night and connected it a cable directly from the POS terminal on my battery to the Green or Blue cables - The motor made no noise and didnt lift/lower
I checked the voltage traveling down the wire and I am indeed getting 12 V down the green/blue depending on which is connected
So, if I understand things correctly I have one of the following:
1. A bad trim motor
2. Something wrong in the hydrolic system
My question:
The tilt is currently in the "up" position. What is my best way to troubleshoot what to do next?
My Plan:
Next I was thinking of taking out the trim motor and hot wiring it to the battery to see if it is making any noise (seeing if its even functional .. does that make any sense?) before spending the 200+ bucks to replace. However, I am concerned with doing things in the correct way as to not introduce other problems (like getting air in my hydro lines) etc.
Any advice any of you could give me would be greatly appreciated. As I said I am a first time owner (newbie) so if there is additional information I could provide which would help please let me know.
Roy
Boat Specs:
My Problem:
1. A bad trim motor
My question:
My Plan:
Roy
