drewmitch44
- Jun 26, 2005
- 1,749
Ok i drained out all the oil from the oil from the oil tank inside the cowling. There is no gasket in the tank restricting oil. the problem that i got is that there is oil in the bottom of the motor compartment. from time to time. I also tested the oil pump like was stated in the manual. Im not getting the 3.9-6.2cc's in the 3 min. @ 1500 rpm. So like the manual said i opened the bleeder valve and its open now. It looks like the oil is leaking out of the bottom of the tank as for some reason there is just a cheap *** plastic wire tie instead of a clamp. The cap of the tank has the 3 sensors to tell the external tank where the oil level is. The cap does not screw on it has like barb type shape to it. 1: Should there be a rubber gasket there or something? 2: why are there just these cheap plastic wire ties clamping off the connections??? (Im going to fix that with clamps). 3. the linkage from the carb to the oil pump piviots(it looks like its supposed too) but on the carb side there is a plastic piece that has 2 holes. Its set on the farther one from the oil pump. On the linkage on the oil pump side is a screw adjustment and it looks like its all the way out (making the pump work more). there is also a hole that i can move like 1/4 inch or so(just like on the carb side of the linkage) which will in turn make the pump open more than it does. Should i mess with this stuff till i get the oil output that i want on each cylinder? This stuff is pretty involved and i hope you understand what im talking about. Let me know what you think! Im getting oil in the lower cowling and im hoping its those cheap zip-ties. and also im trying to get propper oil to the cylinders. Thanks. my email is drewmitch44@comcast.net
