Re: cant advance throttle in neutral
Are you the original owner? And is this a recent problem or has it been on-going since you got the engine?
Reason is: If another person has attempted to raise the idle to correct bad idling or stalling due to improper mixture, timing, or fouled plugs---Then the idle stop screw may be too far in, raising the idle, but taking out all the clearance in the system. When in neutralat regular idle position, there should be about 1/8 inch clearance between the tower cam and the shift stop that it contacts in the cold start, fast idle position. If the screw is sticking out of the arm more than oh, say, 1/2 -3/4 inch, or if the head of the screw is up against the lock-nut, then it is in too far. You need to start at the beginning and reset and synchronize the carb and ignition linkage. Get a Clymers manual or look up other posts on synchronizing carbs and setting mixture. It is not difficult; It just takes some time and you need to work logically and methodically.
