Are you sure it is the bolt and not the weep holes? There are several weep holes under the cavitation plate to drain accumulated water out of several blind compartments next to the water pump. Water blowing down with the exhaust may be entering these compartments, draining out and running along the cav plate to the bolt before falling off. Double check.
