Vinyl flooring?
turfman
My new boat, wich should be called Mr. Scratchy; needs to some sort of treatment on the floors and gunnys so my wife and kid don't kill me.
vinyl any good. Never used the stuff so I'm pretty clueless. Any tips on buying and installing.
Thanks
Mark
JB
Re: Vinyl flooring?
Deck, turfman, deck. Floors go in buildings. :)
I suggest Rhino Liner. It comes in many colors and non-skid can be added.
Boomyal
Re: Vinyl flooring?
You mean something like this.
It's Nautolex. Very easy to install, non slip and very durable.
Mark42
Re: Vinyl flooring?
I think its time to give us all a lesson in laying Nautolex.
turfman
Re: Vinyl flooring?
Boomyal.
I'm pretty sure thats what I'm looking for. It looks lkie flat surfaces should be no problem, I'm wondering if it's flexible enough to follow contours of gunwales etc. Anything special to put it down.
As far as rhino liner; I think that might be a possibility, I'll check that out also.
Mark
Boomyal
Re: Vinyl flooring?
Boomyal.
Mark
Turfman, Nautolex does have limitations in that any contours need to be virtually in the same plane for it to lay down. It is a 'fibrous' backing material with the vinyl applied over it. It does not stretch like upholstery vinyl.
It would also be kinder and gentler on your body than Rhino Liner, although I suspect it has it's merits as well. I also was unaware that you could apply this yourself. I thought it was pretty much a professional thing with specialized spray equipment. (I checked their website and saw no evidence of DIY)
As for application, I use an automotive contact adhesive, obtained in bulk from my local upholsterer and spray it on with a cheap Binks type knock off syphon paint sprayer. It is very neat to do.
I pre cut the material, making sure it fits the area, I then fold the material in 18" sections, back onto itself.
I position the roll in the middle of the project and unroll the top half, making sure it falls where I want it. I then refold that half and start spraying the glue. I spray the exposed backing of the first fold, then the corresponding area on the boat floor.
This is where a few extra hands come in handy. I have two people holding up the outside edges of the roll while I, on my knees begin to press the vinyl to the floor from the middle, slowly out to the edges. This way you get no bubbles. I then go onto the next fold, spraying the backing and the floor and repeating the above to apply it. When I have finished the first half, I turn around and similarly lay the back stack of folds.
Willyclay
Re: Vinyl flooring?
There's a DIY product on the market called Durabak. They will send you a free sample. Can be applied with brush or roller.
turfman
Re: Vinyl flooring?
Thanks for the info guys.
Talked to a bunch of my buddies this weekend while out tuna fishing about my deck covering dilema.
I was told that nautolex was to be applied to the deck and that "herculiner" applied to the sides.
Herculiner is sold at local napa stores and can be applied with a brush. The guy that told me this said he had herculiner on the deck also but thought he could never get it clean enough, so the vinyl went down. I saw his boat yesterday when we got back. Seems pretty nice and fairly easy to do.
FWIW: 12 guys on the boat + captain and two mates. 21 yellowfin, 13 longfin, 1 big eye, and one swordfish. It was a great trip.
thanks again.
Mark
brantly
Re: Vinyl flooring?
can the nautolex flooring be hosed off? i might use it in my ski/fish/cruiser/everything else you could imagine a boat being used for. i boat in the salt water, how would that stuff hold up to a regular garden hose? and is there any chance of damaging the plywood underneath?
Mark42
Re: Vinyl flooring?
Yes, Nautolex can be hosed off. Its solid vinyl deck covering with a cloth backing. It gets glued down.
