jbjennings
- Jul 18, 2007
- 3,903
I've finally made some progress on my merd 9.8.  It had a couple of pieces of hardened rubber gasket or fuel line in the fuel pump check valves which was possibly causing a slight miss as wide open every once in a while.  I don't know if that was the cause but it's not doing it now.  I also have got the water pump working well.  I resealed the lower unit and am still getting a slight leak (milky but not bad milky lower unit oil after burning about 1 gallon of gas).  The only seal that is not new is the prop shaft seal.  Long story why it's not new.  The prop shaft did have some miniscule pitting at the seal like most do.  Here's my questions:   Has anyone had any experience having the drive and prop shaft welded back up and having it taken back down on a lathe?  How did it turn out and how long did it last as far as holding a good seal?  How did you polish it?  Also,  Is the reverse gear supposed to slip on hard throttle ( I noticed the clutch was different on the reverse gear compared to the forward side of the clutch)?.  I'd like to get this old motor in good shape because the power head has very, very low hours and it cranks like a dream and idles and runs wide open that way, too.  I also really like 70's 9.8 and 20 horse mercurys although in my opinion they have some really annoying ignition parts and the drive shaft/prop shaft problems (cast iron).  Mine has the newer late 70's drive shaft I believe, but oddly enough the  part that counts where it seals is stainless whereas the top part about 2 inches out of the water pump up is really corroded and appears to be cast iron. Any other ideas on how to get this lower unit in tip-top shape?  Is there a source for reasonably priced new drive/prop shafts?  Any ideas would be helpful.
THanks,
JBJennings
			THanks,
JBJennings
