Re: Time for rebuild? 1978 115
You might kiss the threads of the head bolts with Sealer 1000 or equivalent to prevent them from "freezing" next time you want to take them out.
Yes there is no need to drain the gear oil when replacing the water pump.
A couple of other things - if you have never replaced the thermostats it might be a good time to do that.
And while you have the heads off you might as well replace the (can't for the life of me remember the name - loosing them brain cells!) diverter hoses that are in the water passages right along side of the cylinder sleve (they look like 1/4" black rubber fuel hose) if they have never been replaced.
