Re: Which Gear Oil Is Best?
			Must LubeDude pimp Amsoil at every given opportunity?
Marine specific gear lubes will have extra corrosion inhibitors and demulsifiers when compared to automotive gear lubes.  I recommend you use a marine gear lube for your marine application.
You really want to start another war don't you?  I guess it's just the way you roll!!!
Universal Synthetic Marine Gear Lube SAE 75W/80W-90 (AGM)
High Performance lubricant engineered to meet the demands of marine applications. AMSOIL Universal Synthetic Marine Gear Lube provides:
Excellent Gear and Bearing Protection even when contaminated with 10% water
Reduced Friction and Wear
Rust and Corrosion Protection
Long Seal Life
Superior Foam Prevention
