tunedportcj5
- Oct 21, 2007
- 4
Hello - I have a 1998 16' Pro Sports Pro Skiff with a 1996 50hp Johnson. I just purchased this boat a few weeks ago. It has some bugs and I am trying work them out.
At first I was having major cavitation issues at WOT (trimmed all the way down) and with any slight turn - it would come "unhooked". After some reading I determined that the anti cavitation plate was too high from the bottom of the hull. I lowered both the motor and the CMC hydraulic trim plate. It is now at its lowest settings and it is much better. The anti-cav plate is about 1/2" above the lowest point of the hull.
My main problem now is that it takes forever to get on a plane. It should jump out of the water with a 50! I have been testing with 2 different props. Both are 3 blade aluminum and are in perfect shape. One of them is a 11.75x15 and the other is a 11.75x17.
With the 11.75x15 it gets on a plane a little faster (30 seconds maybe) and has a max RPM of 6000 (too much). From idle to WOT it jumps right to 5000rpm and stays there until it finally planes out.
With the 11.75x17 its naturally slower to plane (30-45 seconds maybe) and has a max rpm of 5100. From idle to WOT it jumps right to 4000rpm and will eventually plane out.
I also feel that the WOT speed is low. I don't have an accurate speedometer but I am guessing around 30mph.
I also have eliminated any possible engine problems. It is firing on both cylinders, good compression (~135psi on both), carbs have been checked and cleaned, etc...
I am sure that the props do not have spun hubs. The 11.75x15 is brand new.
Whelp... thats my story. Does anyone have an idea of what might be going on?
Thanks!
David Smith
Jacksonville, FL
Thanks!
David Smith
Jacksonville, FL
