35 hp Johnson sea horse
mainetexan
I recently was given a super sea horse the serial number is 1968902 & Model is RDSL21B can anyone tell me the year model.
mainetexan
Re: 35 hp Johnson sea horse
Thank you very much high trim would you know where i could get a repair manual .
Thanks
Mainetexan:)
JB
Recommended Manual is the original from OMC, MaineTexan. Try kencook.com.
Meanwhile, your fuel mix should be 24:1, one quart TC-W3 oil to 6 gallons 87 unleaded.
Spark plugs are Champion J4C gapped at .030". Points set at .020"
Really curious about the MaineTexan handle. :)
HighTrim
Here are a few options, first the kencook website
"http://www.outboardbooks.com/index.cfm?fuseaction=models.main&year=1959&ID=55366"
Then try ebay, this guy usually has alot to choose from
"http://search.stores.ebay.com/SEARAY...ageNameZRC0024"
Laingsoutboards is another site
"http://www.laingsoutboards.com/literature.htm"
Good luck.
Jerry900
I have a Johnson Model is RDS21B.
One manual is
"1956-1970 Johnson/Evinrude Outboard, Volume 1, Tune-up and Repair Manual, 1.5 HP thru 40 HP" by Seloc Publications
An original OMC manual is
"Johnson Service Manual Tenth Edition"
I found the first one at my local library.
tashasdaddy
that is correct. i have the manual.
it is a dependable motor, check you compression and spark. to see if you have a viable base to work with. to be dependable, you will probably spend in the range of $200 to change, point, condensers, coils, plugs, and wires, carb kit. a must do is to service the water pump.
it is a simple motor to work on, if you are mechanically inclined.
good luck, and post any questions.
mainetexan
:)Jb I lived in Texas all my life a Native Texan but Married a Mainaic moved to maine divorced the Mainer but decided to stay the rest of the story.
thNKS FOR THE INFO ABOUT KENCOOK.COM.
Thanks
Mainetexan
How about them red sox's
