Help Trying To Identify What Model An Year Mercury 40 Hp
my motor is on an 84 skeeter the boat an motor were purchased from the same marina but im unsure of the motors year the serial number is
5416064
Re: Help Trying To Identify What Model An Year Mercury 40 Hp
did not see my serial number listed hmmmmmmm
domains
Banned
someone will help you ...i found my 40hp there though . maybe yours is newer than 96 ...not sure.
skimmer
Merc 402: 1979
thanks appreciate the help will this motor charge my battery or does it only have electric ignition
also this motor is in excellent shape i would rate it a 9 outta 10 cause its been hardly used very clean always stayed in a garge anybody know what kinda money this would pull im looking to either upgrade to a bigger motor or a smaller one
Laddies
Banned
That engine came with a alternator
AMD Rules
Motor is definitely a 1979 Mercury 40hp 402 as was indicated earlier by skimmer.
It -might- have a charging system. Look for yellow wires coming down from under your flywheel, and see if they go to a rectifier (small square item with 3 terminals, as per image below) and then onward to the red lead on the starter solenoid. If they do, you are charging your battery.
The 2 cylinder Merc weren't known to be the most reliable motors they ever built. Street value is too dfficult to judge sight unseen.
very helpfull forum i came from another forum for my last hobby (racing radio controlled cars) an i love having genuine people to help out thanks everyone i really do appreciate it.
the boat is in very good shape little floor rot is al cut out an ill be putting some new plywood patches an i redid all the electrican set the boat up with depth finder an all new dual batterys an switches for everything im looking for either a smaller 4 stroke 20 hp max for a local lake or a bigger 2 stroke to run up in the deleware rive north of philadelphia so im kinda wondering if the 2stroke 40 is gonna do the job
also the boat came with a johnson sea horse 9.9
