Re: 1976 55 h evinrude
On the inline spark tester, how large a gap will the spark jump with a bright blue ZAP!! 7/16 of an inch? Do you get spark on both cylinders equally? I would look into the boots like TD said and check the condition of the spring and spark plug wire. If it is corroded or rusty at all, you will need a new boot kit. Cut back the wire, allowing enough to still reach the plug, remove about an 1/8 of an inch of insulation, fold the expposed wire over, slide the new spring through the wire, lube the wire, then slide the new boot over top. A little grease in the boot should help as well. Also check the condition of the plugs fully, the porcelain may be cracked or damaged.
