Brave 3 sterndrive removal
homelite
I found a PDF online of how to inatall, but how do I remove as far as the shift cable is concerned. Pull in neutral? It appears that there is a cable that you just unhook? It is an 06 in my bosses cruiser and I don't want to screw anything up. Are the "U" joints lubeable?
Thanks
Shaun78
Re: Brave 3 sterndrive removal
The shift cable jaws open up when you pull the drive out and the cable releases itself. I just took mine off and yes there are grease fittings on the u-joints. Put shifter in Neutral also.
Shaun78
Don't for get the speedo tube 1st and then put the drive all the way down
TilliamWe
Banned
Ujoints are lubeable, if the drive is old enough.
