Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
model # 15gg-9014, serial # 360890 , would like all possible info ,year, actual manufacturer , color picture and /or discription of original colors . just bought today, want to refurbish , use on new homebuilt sail boat as back up.
Your motor is a 51 Built by the Gale devision of OMC.It is based on the Gale
5S10 2 cyl. 5hp at 4,000 rpm,1 15/16 bore X 1 1/2 stroke.8.84 cu. in. 2 blade 7 1/2"D X 7 1/4 pitch,13:20 gear ratio.360 degree reverse.
.8 gal tank about 1 hr run time 45lbs.water pump is behind the prop.
Champiuon J6J(J6C)plug set at .030.Points set at .020.
Can't help on the colors but if you go to aomci.org antique Outboard Motor Club I think you'll find info decals etc.
