Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I have a 1991 25hp. I am seeing a lot of oil residue coming out of the bottom of the cowling. Not sure if my float is sticking or what. Motor runs just fine. Worried about potential problems.
Pump the fuel bulb up and look for leaks around the lines and carbs.If it was a needle and seat stuck open then the bulb would not pump up firm.
I had the same problem and it ended up being a leaky line under the top carb...
