Mariner magnum 40hp has the wobbles
dannat
G'day guys
my mate has a 1990 mariner magnum 40hp. the problem is the mounting bolts that hold the motor to the trasom bracket have gotten loose or some thing has let go right under the block you can pull the top of the motor back and forward :eek:has any one else had this problem and how you fixed it cuz it looks to us that we will have to pull the motor of the leg to fix it
thanks dannat.
skimmer
Re: Mariner magnum 40hp has the wobbles
Why can't you tighten the bolts.
JCF350
Your going to need a service manual. Look up replacing engine mounts when you get one.:)
