Re: 1969 evinrude 115 hp pulse pack trouble
OK, everybody let's clear this up. It's been 40 years and I got to wondering if my brain is still intact, so I got the factory book out.
1. We are talking about a 1969 115hp here, not necessarily other year/models.
2. It has an "IGNITION SAFETY CIRCUIT", not a "clipper circuit". They are not the same thing. The safety circuit is to prevent ignition before the starter is cranking. It does that by sensing alternator output and when it sees alternator output, it "turns on" the power to the pulse pack. (Purple/black wire).
3. If the safety circuit is not working, you will get no ignition spark.
4. If the alternator is not working, the safety circuit will not turn on the power to the pulse pack and you will get no spark.
5. If the safety circuit is OK, but the alternator is not working, several things could be the cause:
5a. Rectifier
5b. Shift Diodes
5c. Alternator Stator
5d. Tachometer.
TO TEST SAFETY CIRCUIT OPERATION:
1. Check for 12v at the purple wires on the terminal strip with key turned on. If OK,
2. Check for 12v at the purple/black wires while cranking with starter. Should be voltage only when cranking. If no voltage when cranking,
3. Use a jumper wire between purple and purple/black wires on terminal strip. Check to see if you have spark when cranking with starter. If you do, the pulse pack and coil, etc are OK.
BENCH TEST OF SAFETY CIRCUIT
1. Connect a #67 bulb between safety circuit purple/black wire and housing of safety circuit
2. Connect a jumper wire between housing of safety circuit and negative terminal of battery.
3. Connect another jumper wire between purple lead of safety circuit and positive terminal of battery.
4. If bulb lights when above connections are made, safety circuit is defective.
5. Bulb should not light when above connections are made. Touch each remaining safety switch wire (yellow and yellow/grey) separately to the battery positive jumper wire. Bulb must light when either lead touches positive lead or safety circuit is defective.
The alternator must be working in order for the safety circuit to operate. If your alternator is not working, check items listed under 5a through 5c.
Whew! No wonder I had to get the book out.
