Re: Mercruiser 140 points to electronic ignition
Thanks to all who recommended the Pertronix kit. Just bought an '86 Celebrity with the 3.0L Mercruiser and decided to upgrade. I ran into a small issue during installation which others might also run across. The hall-effect coil which inserts down over the distributor shaft seems like it is seated properly when it really needs to move down 3/16" further until the lip of the top of the coil joins the reduced diameter slot of the distributor shaft.
I installed the kit, figured the coil was seated all the way around, and installed the rotor. Started the engine but spun the rotor since the key was not sitting all the way down on the shaft causing the engine not to start. Bought a new rotor and cap, removed 1/4" off of the bottom of my rotor to ensure the keyway would fit, but the engine ran very rough. With a timing light, I noticed that the #1 cylinder spark was sporatic. I had purchased a second Pertronix kit as a back-up and tried that one...now cylinders 1, 2, & 4 fired as expected, but I could not get cylinder #3 to fire. I tried swapping spark plug cables and spark plug from #3 to #4, but still had no spark on cylinder #3.
So I wrote to Pertronix...they told me that I probably did not have the hall-effect coil seated all the way and that I should not have needed to remove any material from the bottom of the rotor. They suggested taking a deep socket and a hammer and tapping the coil down further until the lip seats in the groove of the distributor shaft. I did this, it took the hall-effect coil down another 3/16" and the engine started like a champ!
When the hall-effect coil is correctly installed, it appears to sit lower than expected when comparing to the height of the module...this is apparently normal!
I have attached a few pictures to illustrate...first two are wrong installation with the hall-effect coil being too high, second two are correct hall-effect coil installation.
