There are two exhaust holes on the back of the engine just below the bottom cover. There should be a smal spray of water comming out there at idle and at least one side should pour water out at anything over 1500 rpm
You could also retrofit a tell tale, see IWombats thread in the FAQ. Also make sure you maintain that water pump, changing the impeller every couple years.
