starsnstripers
- Nov 30, 2007
- 1,330
1968-72 155hp gm 250ci l6 pre alpha outdrive. I have a spare outdrive can i take the spline shaft apart at the u-joint and use it as a line up tool to get the motor, mount and belhousing shimmed correctly? it's al apart so i dont know what or where any shims should go especially on the stern mount the front is adjustable. I dont want to cook a gimble or u-joint or outdrive bearing.
