Re: 1983 evin 150 crossflow upper crankbearing
I went through this a couple of years ago. Torrington makes the bearing, but will not sell to the public, as it is an OMC design. Berry Bearing cannot get them. Proprietary and all that stuff. Wound up buying a complete head assy from ebay. I know there is an upper brg on ebay now, but don't remember if it is for a crossflow. Greg is right, the V4's and V6's all use the same one. There must be thousands around. Am sure you can get one from Boat Recyclers of Wilmington-Check the web. Unfortunately, when these bearings go, they tend to damage the upper crank journal, so be sure to check that journal carefully. Be sure to replace the upper crank head seals. Good luck.
