drewmitch44
- Jun 26, 2005
- 1,749
Ok you might have seen that ive been opening up the bow of my boat. Today i found some wet foam under there. I started ripping up the deck and found that the foam was only wet up close to the bow. Im going to rip the whole floor up though. Someone recently replaced the stringers all but the bow part which was closed and raised. The stringers are new but i have the floor almost all the way off. I pulled about 200-300 pounds of wet foam from the bow. Whenever the stringers were replaced they added a cross board and there was no drain in the center. so water collected there and soked the foam. Well im going to have to reglass the stringers that are there and put a new floor back in. I have used the bondo brand resin and glass from wal-mart on the last boat and i got "ok" results. It might have been me but i like to think that that stuff and not me. What kind of resin do i need to use and is there a place locally i can secure these things? I will use the bondo brand again but id like to explore my options. What kind of resin is that anyways? and what am i supposed to be using? Thanks for any help guys!!
