Re: 21 ft Manatee, new motor
21 foot Manatee cuddy is rated for 170 max. (Listed in the catalog as a 20 foot boat--actual length 20"9") Mine --a 1988, because it is over 20 feet long, has no capacity plate. Only has a statement that it complies with Coast guard regulations at the date it was built. If yours is not a cuddy, the horsepower is about 10-20 less but that's just a guesstimate unless I can find the VERY safe place I stored the catalog. Cuddy hull weighs 1600 lbs bare--no engine, fuel, battery, canvas, or GC equipment.
Engine size is listed in the sales catalog. It is interesting that the catalog states maximum horsepower as 170 but the photo shows the boat with a 90 on it. I also found it interesting that the 19 foot cuddy is the exact same boat with 2 feet less length at the stern. All other dimensions are the same. I think it is rated for 140 hp. I had a 125 and now have a 140 on my 21 foot cuddy and would like more. It gets 38 MPH at wide open throttle. 90 or 115 will be slightly underpowered even though either engine will get the hull onto a plane at somewhere around 15 MPH and deliver a top speed around 28-32 MPH. It is a narrow hull with a fine entry and wide flaring bow, so it is an excellent bay or ocean boat. However, because the hull is narrow, at speed she tends to roll or list to either side as passengers move or change positions in the boat.
Do not worry about fuel economy. It will not be a factor with any engine unless you run it at wide open throttle at all times. In other words, no matter what size engine you have, within reason, it will take the same amount of fuel to go the same speed. With the larger engine, you can go faster and will then use more fuel. But it's nice to know you have the reserve power and speed if you need it.
