From what I understand about gelcoat is that it is used because it is also a fiberglass release agent so it saves time in the building process.  There are many new marine paints that are enamel and I have seen some imron paints for boats.  I talked to a guy that built custom boats in the late 50's and 60's and he said he used lacquer.  I see that Duplicolor has a system that includes the primer, paint, and clearcoat with no mixing or thinning. It is a lacquer system and can be resprayed anytime.  I checked with Duplicolor and the system is compatible with fiberglass.  Does anybody know if lacquer would hold up on a boat that is used maybe 30 hours per year?
What about the advantages and disadvantages of the different types of coating, gelcoat, enamel, imron, lacquer, etc?
