Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I removed some layers of paint and smoothed out with 180 grit. Some down to fiberglass. What would happen if i primer and paint over the original sanded paint?
Re: Gelcoat Polyurthane paint over original paint?
Are You Going To Use Gel Coat Or An Epoxy Type Paint? I Just Re Finished A Bass Boat With A Clear Gel Coat Sprayed On And It Really Brought The Old Color And Glitter Back. All I Did Was Light Sand And Cleaned It Real Well And It Adhered Ok. Make Sure There Are No Wax Or Oils On The Surface.
