G'Day All, and a Happy New Year.
I have completed the following that the manual specifies for the removal of the gearcase. Removed shift rod screw and the pin in the linkage, disengaging the shift rod. Then removed the trimtab and bolt. Removed the 5/8 countersunk screw and the bolt in the trimtab cavity. Then removed the four gear case screws. After prising with screwdrivers,flogging with a rubber mallet and shaking,followed by violent shaking.
I am still unable to separate the housing from the rest of the motor.
:redface:
Should the motor have been in gear when the shift rod was removed,manual does not state this.
Have I missed something not written in the manual?
Any advise/help would be greatly appreciated. Thanks.
