John MD
- Jan 7, 2008
- 7
I have all but decided to go ahead with a quick tear down of a replacement 3.0L 140HP inline 4 before installation. Been looking at the service manual and it so far seems pretty straight forward. Going to do it myself.
Any pitfalls to watch out for on this motor? What parts need to be replaced that otherwise you might not on another motor...i.e. valve springs, oil pump, rod bolts, water pump, etc.?? Are the pistons, pins typically reuseable? How do the cylinders typically wear and what to look for with this motor?
Any head issues inside the combustion chamber? Where is the best place to get guides, stem seals, valves, bearings, gasket kits, etc? Are you guys using teflon, viton, or something else for stem seals....And are you using them on the exhaust side as well (old 73 140HP)?
Are the cranks nitrited? Do they typically wear evenly only requiring polishing...or require turning with undersized bearings?
Well I know this is quite a bundle of questions. Just looking for good solid building advice as to kind of what to expect.
Thanks in advance,
John M
Thanks in advance,
John M
