Substitute fuel pump kit for 18 hp '71 Evinrude?
ba_50
Hi
I've got a 1971 18hp Evinrude 18102S. There is a Sierra kit 18-7042 for the fuel pump, but it doesn't have the diaphrams included. Evinrude doesn't have a kit. Is there a substitute like 18-7823 that will work? Thanks.
rickdb1boat
Re: Substitute carb kit for 18 hp '71 Evinrude?
18-7222 will have all the parts you need. It is a replacement for the OEM 396701 kit..
ba_50
Re: Substitute fuel pump kit for 18 hp '71 Evinrude?
Deleted due to confusion on subject
samo_ott
18-7402 at vintageoutboard.com shows 1 diaphram. How many should there be?
ba_50
There should be 2 The one not pictured goes on the round side of the pump and has a big spring in the middle. If I have to I could order one separate as they are in 9.9's and others. I don't understand why they don't include both.
samo_ott
Weird. And you cant get the kit from OMC? I can get kits for my 50's and 60's 18's from OMC so I would think it's no prob to get one for the 70's?
ba_50
No, they only supply pumps for this model. They can make more money that way I guess.
F_R
What the.....? Diaphragms and float in a carburetor??? Carbs have a float but no diaphragm. Fuel pumps have diaphragms but no float. What are you working on anyway?
jay_merrill
LOL @ FR. I was thinking the same thing!
samo_ott
That was my first thought also until I looked at a pic of the carb kit and there was what could be called a diaphram in it. I guess it depends on the definition. There's certainly nothing like it in the older carbs kits I get and install.
F_R
OK, I looked at the picture. But I don't see anything like that being used in a 1971 25hp. Maybe in a newer something-else. I'm very familiar with the '71 models, but not the something-else new plastic stuff. Either that or I'm getting oldtimers disease, which is a scary thought.
ba_50
Sorry guys. Not sure where my head's at. Been having a lot of trouble with a craftsman carburetor. Dealing with the State of Il govt. on a problem really fouls things up too. It is for a fuel pump. Guess I'll have to start over. I went back and deleted some posts and changed the others. I hope this doesn't confuse everyone further. Again, I apologize.
samo_ott
When in doubt, blame the government!
ba_50
Aam,
No, this problem was my mistake.
tashasdaddy
why don't you start a new thread, i'm totally confused.
ba_50
Excellent idea, I will. If I could delete this one I would.
