Simoniz
- Dec 30, 2007
- 251
Hi I have obtained a puller to remove the harmonic balancer from the front of the crankshaft of my 2001 year Mercruised 3.0l engine.
The bolts supplied with the puller are metric and so dont fit the threaded holes in the harmonic balancer which I assume are an inch based thread (AF, BSF or similar).
I want to buy the correct bolts and also a tap to clean up the threads in the HB which are a bit rusty.
Does anyone know the size and type of threads used in the HB? They are similar (but not the same as) M8 fine ie fine thread approx 8mm outside dia.
Many thanks.
Many thanks.
