I am i the process of hard wiring my 20 hp johnson 1972 model, but I have a few questions. My male/female connection point was corroded, so I thought I would hard wire everything. I noticed once I had everything apart that there is 5 small wires coming out the female side, but only 4 small wires coming out the male side of the connection point. The extra wire is a green wire that comes from the elec. choke/key switch. I know the two small black wires go up to the points/magneto assembly, the red wire goes to the choke sloenoid, and the white wire goes to the starter solenoid, but I dont know what to do with the green wire. Also does it matter if I get the two black wires that go up into the flywheel assembly flip flopped in the process?
