Re: Boat off the trailer?
I suppose the best way to do this, is jack the boat up at both corners in the back, one at a time using a hydraulic jack, with some wood as a cushion between, then set it on a couple house blocks (cement blocks) on each side, with a block of wood on top, then carefully jack up the keel while still on the trailer, and begin to roll your trailer out, till you get to where the jack is then drop the boat back on the trailer till you can reposition your jack in the middle, then continue doing this till your trailers out, then chock up your keel, with house blocks, & a block of wood and remove the jack, thats it.
