jbjennings
- Jul 18, 2007
- 3,903
Guys,
I've been trying to mix/match some crappy gear parts I have gotten to try to fix the l.u. on my 10hp. I have gotten it back together but can't figure out why that it won't come out of reverse or forward unless I go a little past neutral for both gears. I.e. - go to forward, it goes in gear fine but when I go back to neutral, it's still in gear. If I go a little past neutral, it comes out and stays out when I let it back in the neutral shift notch. Same thing for reverse, I have to got a little forward of neutral to get it out of reverse. I've tried adjusting the shift lever, but this is the best I can get it. I've checked the shift rod linkage in the midsection and it's o.k., too. Also, I noticed that the prop shaft that came out of it had a hole drilled through the spines and a spring in the center of it with a ball bearing on either side. The "new" one I got doesn't have that. Could that be my problem?
Thanks,
JBJ
Thanks,
JBJ
