Re: Ignition problems w/1996 120 force
Even when you turn the key to off position? Sounded like one of the wire is on the accessory terminal which would keep the motor running with the key on acc. position. Is the new switch the exact same make and model as the old switch? If not then you should get a diagram of both the old and new switch and then goes from there.
