Saw a similar thread about a beeping problem. Mine is a little different though in that mine is a solid beep. I know that this is usually caused by an overtemp. My engine will get the solid beep when putting out of the marina or just sitting idling while getting ready to go out. Sometimes I just shut the motor down and then turn it right back on and never have a problem the rest of the day. I have run the motor a good 20 miles one way after the alarm goes off and never had an issue, knock on wood. In fact it's every time I got out the alarm comes on, I either shut down the motor or rev it up and the alarm goes away and it doesn't come back on for the rest of the day. I get the beep once in the morning, do a shut down or rev it up then it's gone?!. The engine has never seemed at all hot and in some cases not even warm. Water comes out the pee hole just fine, and the water temp never is really that warm?.
Suggestions?
THank you
Suggestions?
THank you
