Did a pressure test on the lower unit, since it has been quite a few years since seals have been replaced. I put together a homemade tester with a hand pump,an old automotive fuel pump/vacuum tester, and some rubber hose. It held 3 lbs for 5 minutes with no sign of leakage. Pumped it up to 10lbs, and it leaked down to 9lbs after 10 minutes. Is this good enough, or should I just put in new seals?
Thanks.
Thanks.
