well i put the boat (1985 hydra sport bass boat) in the water today after sealing the new thru hulls and new drain plug and no more leaks !!!
so now onto the next fix i had a soft spot in my floor between the seats there is a floor drain here similar to a shower drain, well the grill is anyways....the area is probably 7"x7" and whouldnt you just know it was right on top of the stringer (dead center of the boat) and the foam ....it was about a 4" drain.....there is a section of the stringer that is starting to rot it is the dark spot in the picture just left of the screw.....how can i fix this please dont say take the top off and redo the whole stringer
the weird thing is i poked a hole in the foam and no water nothing but dust came out but how did the plywood on the floor become rotted ?? it was sitting on the stringer so i guess it stayed wet ?? and why wasnt the foam saturated ??
the front of the boat has a drain also this one is beside the stringer which is glassed in i can see through the hole...should the new floor have drains like these maybe just in different places ???
