Re: Explorer Bumper Hitch - Should I use this or add a frame hitch?
			I have a 2200 lb 1974 Bonanza (has anyone ever heard of this boat company?) with a 165 merc i/o.   I am using an explorer 2wd with the bumper hitch.   No problems yet, but I notice a number of explorers with larger hitches.   Am I taking a major risk by using this trailing method?
You didn't say what year Explorer you have, but if its a late model, the bumper hitch is rated 3500 lbs trailer with 350lbs tongue weight.
For those who think the factory bumper hitch is weak, you should get under one and check it out.  There is some serious thick steel plate that is much thicker than many aftermarket bolt on.
Unless there is some collision damage, or severe rust, you are only using 62% of the bumper hitch's capacity.
I have been towing a 2000 lbs trailer with my Mountaineer bumper hitch and have no issues at all.  And yes, there are safety chain connection points.
You would be smart to spend your money on something else, and keep the extra weight of an aftermarket hitch off the truck.
